thickness base view line
  • Thread starter Thread starter davix84
davix84
Hello everyone, I started using the "basic view" command in autocad 2013 but I can't give the line thickness on the layout once you create the views from the 3d model.
do you know how I can define the line thickness within the views?
if by "basic view" you mean _solprof, once you get the blocks you edit them by setting different colors or line thickness. otherwise I did not understand the question
No lattu, it's another thing.
@davix84
you have to act on the layers; to the creation of the base view and all other views are generated layers called md_<qualcosa> which contain visible lines (md_visibile), invisible lines (md_nascosta) etc.</qualcosa>
