vale61
Good morning,
Every now and then I get resentful.
I should design an equipment where to insert a particular aluminum box.
The material would be a 46100 between the possibilities I'm evaluating the meltdown.
having had to deal only with the prefusion I would like to understand gross (just to give an order of magnitude achi will fea) of how much I should increase the minimum thicknesses to obtain the same structural resistance.
I know that the question is a bit generic, but for the moment it would be enough for me to have an idea of maximum or to know that it is not possible to make a direct comparison between the two processes (I see that I do not know the different problems that could be in the merge on earth with die casting).
the box would have external size of about 300x300x100 (die casting thickness 3 mm)
Thank you 1000.
Bye-bye.
Thank you 1000.
Bye-bye.
