dinan_3dforum
how do you move the work plan through values in x y and z?
or is not + contemplated the command?
in these days I became mad the solution but found it:how do you move the work plan through values in x y and z?
in the 2007 version with a dx button on the work plane and then change the work plan opened a table with which you could translate or rote the piece giving coordinates if that's what you mean, in 2008 this you get it with the commands I told you...Yes, but I didn't mean that.
in previous versions (until 2008), with the command "worktop - move) opened the window with all the options (wheel, move) with the numerical values to embellish in the boxes according to the x,y,z axes.
here is the function shifting with increment according to the axes.
While x rotation and moving it to a point is as you say...
Thank you
