beppe296551
Hello guys, I would like to know, a third plate mold that function has and when it is preferable to use it? and with which polymers it is preferable to use it? My is simple professional curiosity.
I add to the right mocca opzine.
in case a particular print should be obtained with multiple injection points without the use of hot chamber, the casting channel passes between the matrice plate and the head plate.
an automatic mechanism at the opening provides to create the expulsion of the pultipoint casting.
this option allows on rather critical details about fillings to add later other injection points without overturning the concept of the mold. (which can be stacked with a hot room.
can be used with almost all thermoplastics .
I add just to punctuate even if you have already said everything, even the case where I find myself having some males in part fixed. by means of the movement of a third plate in l.f. I extract the manufact from the aforementioned males:finger:I add a further use, although the other interventions have already said practically everything.
In fact, I think of the case in which to "force" the extraction of a small sq (clip or similar...) but in order to allow the plastic to elasticate it is necessary to remove half (heat by third plate) steel parts that would prevent such elastic deformation.
but this is only an example, it is also not said that you have to use the third plate.
hi to all, I agree with mocca and add that I often use the third plate to make it arretrate, before the opening mold, dowels or thorns that tie a lot to the piece and maybe they would make it stay on the injection side.is used when it is necessary to "heat" subsquadri even before performing the mould opening between matrix and punch.
