thread holes on welded assemblies
  • Thread starter Thread starter braunfish
braunfish
when I need to file a hole on one side, I create the hole and then use the appropriate command to file.
But now I have to create threaded holes on a welded set, so after creating the assemblies of several parts, I have made drilling work on the axieme. How do I add the thread?
do the threaded hole instead of two separate machining, the threaded commuter together is not there.
when you can do it in the parts, do the threaded hole, use the thread command only for the trees.
Thanks for the tip.
Can you tell me where I find or how to add this command in the mechanical machining panel?
(pro 2010)
Thanks again.
do the normal hole and in the window you can choose below what type of hole to perform (normal, threaded, with game, conical thread).
I have not yet had the opportunity to install 2010 so I don't know if changes have been made of this command... until 2009 it was so...
All right, thanks,
I used the wrong icon, so a m12 instead of filettarmenlo forged me 13.5, which instead should be the right diameter for us to easily pass through a screw m12
no is always the same:)
It's always the same... but they finally realized that a blind hole is never completely threaded and no longer appears the tick on this option.
one thing they haven't solved yet is that if I make a hole m6 on a face, then I go on a second face I make a threaded hole what you propose is not a m6 but a m5. to the next hole from m5 I go to m4.5.
I have set as representation the diameter of the hole, he recurres this and considers it as the diameter of the thread. How many versions will pass before it is resolved?
hi and good evening
