thread is not seen in solid
  • Thread starter Thread starter andrea1974
andrea1974
I've already seen that you've talked about it but not in solidworks 2021 that I use... You don't see the threads in the solid, I mean, I'm gonna make a m10 threaded hole, and you just see the 8.5 hole where the thread went? applies to any threaded hole, din, iso; hooks, etc...
eehhhhhh mystery mysterious.... how do we guess without files, without images, without description of the utlized functions.... would you succeed?
these are largely threaded but you do not see.. .
certainly with that image is all clearer.
could be:
the annotations off
not inserting cosmetic thread
suspension of cosmetic thread
annotations -> details -> display filter (cosmetic fixtures, shady cosmetic threads)
... annotations -> details -> display filter ( cosmetic fixtures, shady cosmetic threads) ...
Wait.. in the table or solid?
refers to the annotation card of the function tree in the environment part on which you have to press right button.
and with this we would be at 4 possible reasons why you do not see the threads.
controls to do to circumscribe the problem:
-to verify that the cosmetic thread was included at the time of creation
-to verify that the annotations are visible (menu displays>hides/shows> all annotations)
-to verify that the cosmetic threads (if present) of the drilling functions are active and visible
-check that the item cosmetic threads of the details card are selected
nothing has been known about the mystery, so I'd say you brilliantly solved the problem. Congratz! :
No wait, I'm still blaspheming... :cool: now I see it on the table but not in the solid..... It's already a step forward. .
if you see them in the table means that in the model they are present; this narrows the field of possibilities.
if you do not write that you have made the checked and their result and/or if you do not attach any images (details, menu show/hide for example) that can help you understand or even better the file or write that you have made the checked you are limiting our chances to help you.
ok now you see .. hide all kinds of annotations was disabled, but now I lost them at the table.. .
.... check that the view is in mode high quality e non in in bg. . .That's all right. . .
I seem to have solved, now we see both in the solid and also at the table.. .
you are mythical:-)
As the 1/2" hole is made in two parts, a father and a mirror, I had marked the cosmetic only on one of the two and doing the section, the other in the table I did not see the thread. Now I made them both on the solid and they both see each other at the table
