countach3
hello to all are a pro-and wildfire 4.
I'm trying to make a semi-duty for my bike but I can't make external and internal threads.
I better explain the problems I've encountered:
on the external thread I have seen on the forum that you have to use the cosmetic command>filetto but I have not understood well if I have to create the cylinder of the diameter already correct, and moreover it does not allow me to give it some standard threads (e.g. m8) I will not have to build every time a thread!?!? ! ?
on the inner thread instead, I arrive at the window to set hole and thread but, once set (e.g. m8) creates a thread hole of about 0.2 mm!!!
Thank you so much!
Thank you so much!
