threaded holes
  • Thread starter Thread starter zanna83
zanna83
hello to everyone, I tried with the search but I did not solve, unfortunately.
the problem I think has a trivial solution, but not knowing it...:confused:
on a modell make a feature threaded hole a m8x1.25 iso
in the table I see only the ø6.8 without the std representation of the thread with the 3/4 circle of ønominale(8)
I have the wf5 version, I have seen that you can use cosmetics, is there any way to avoid it?
check your options well while doing the hole, maybe you didn't 'press' the taping button (over a shape) and you did the hole without the thread, maybe that's it, hello.
if you see the thread in 3d (cutting the color you see a surface, purple or other color depends on the settings) then check the file design configuration file xxx.dtl
