threads and saw pieces
  • Thread starter Thread starter ipotemusa
ipotemusa
I apologize for the banality of the matter but they have expressly asked me that in the metric quotas std does not appear the step, I explain better:
m10x1.5 is standard big step, they want that in the table only m10
How do I do that?
I searched on the forum, but I did not find answer.
I looked for inv options, but I found nothing
The other questionnaire, when placing an object from the centre, is not dissected, nor by the views section in 3d in the table.
I want to do the same thing with trees and thorns that I design, how do you do it? Where's the option?
Sorry for the banality, but I'm not an inventor, they put me in front of their workstation and they told me: "work...." :smile:
silvio
it is feasible, I do not remember the exact procedure, but you have to act on the excel file to the thread calculation sheet to use at the column "custom voice" or something like that, I think it was the only column of color other than the others, write that you want (also pinperipettenusa, to say) and when you quota, dx key on the hole quota and you select "custom cell thread" (or something similar) and or for automatism they edit the quote styles of the hole and put the correct parameter for the "customized nomenclature". I know I haven't been very clear, but try and if you have any doubts ask, it's a start.
for the section there is another recent discussion, comunqque is a check to remove or put in the documents properties of the part (type "lost section" or something like this).
I'm sorry for the little presumption, but I don't have much time to try now.
threads
you need to search for the thread.xls file that should be in "...programs\autodesk\inventor 2010\design date" and edit the column "custom thread designation".
Sections
open the ipt not to be dissected, document settings->modelling-> flags to participate in section together and drawing, then go in ... application-> option together-> remove the flag to seziona all parts, try and let me know.
regarding the section in the table set the selection filter to select priority part" select the tree or part that you do not want to dissect "right key" "participation in the section" "no"
threads
Sections
I didn't see that flag on the ipt, man, and I looked for something like that. . .
Thanks to everyone, now it works as I wanted.
however do not fear, I will hold you with other disturbing questions!!! :biggrin:
threads
Sections
Uh, I also like myself that the big step thread is only identical with m or alllpiu' but. so now I would like to edit the file.but I get a question even if indirectly connected:when will you switch to a succesive release, these changes to the thread.xls file will be overwritten by the new installation?
no because for every new release there is a new file thread.xls
right, every release has its thread.xls. if I pass to 2011 I have 2 ways to keep the changes: or overwrite (or replace) the file of 2011 with the same of 2010 or I say inv to point to that of 2010.
always that it doesn't happen. .
that "square" or that someone else's request goes.... but for years now that but, mb, mc, .... are no longer normal, it is used m + diameter + step. m10x1.5 is in accordance with 10ma no... then if it is only question "esthetics" is another account...
I prefer to change the file to every release change because I do not have the certainty that they are perfectly equal and replaceable.
but the file of the last release maybe does not delete it, but I put it aside, for a possible incanstation.
you know that:smile::smile:.
I also have custom threads, and then, I already have macros to be added to the new templates, I don't want to shred me even for threads
I make 99 % drawings for internal use... .
I am also particularly interested in editing the xls file. from how much I know (but I don't want to be denied since 2011), the latest versions have kept the same file (unfortunately, I don't manage the network basing myself on third-party information... :frown:). Has anyone ever been able to verify this?
I'm sorry, tarkus, but how do you think you can point him to the xls you want? to the eye, I would say you can set the "configuration" folder, not the single file... :frown:
(and honestly, it doesn't seem like a good idea to point a new release to the design center of the previous :biggrin: )
In fact, pointing it to a copy of the entire design folder given in which I put my modified file.
Then, it should be seen if this could have some inconvenience. . .
threads
Sections
I tried to do as you said but when I make the table the step comes out anyway... you know why?
if I don't remember badly you should delete and remake the hole in the ipt, only then it is correct.
Mauro m, I'm trying and trying but I can't solve the problem.... .
I would ask you this: Can you post the sheet in excel that you modified so I try to replace it with mine to see if it works? ....always there's nothing private on the sheet....or private. I ask you this because I am going crazy to solve the problem!!!
