threads
  • Thread starter Thread starter portosanto
portosanto
I am a new user of catia v5, I found that it catches while having the thread command, it does not show them graphically. I don't have this problem with inventor. Is that my problem or my cat? Thanks to who will answer me.
Bye.
I look more experienced than me, so I felt I understood that you don't show them.
I did the tutorial of the "coffeee" and actually to show the thread you had to generate it by hand, creating a pocket with a propeller.
That's right! cat v5 does not show the thread, it makes you see in the logical tree that there but graphically does not display anything, while you have made the thread through a bolean operation, subtracting material with a section! I think you used the coast command!
I'm sorry, I meant with the scanal command! see the .catpart file that I attached to you and see in the logical tree all the steps!
in an old discussion (perhaps before site crash) someone had posted a file with the thread you see (type sw). Maybe someone has the file or remembers something in +.
Hey, guys.
but in the end it turned out as it did to do that thread command, but above all it understood how you can edit or where you find a file origin where you change?
thanks to all:finger:
According to me is the result of a macro, activable by button, that someone made leaving as variable after the macro the length of the thread.
probably the filet data are set in the macro.
You should find who did this macro to request the source.
