matteo calzaferri
Hello, everyone.
I decided to create this new post because looking both on the network and on the forum I found nothing exhaustive.
I would like to create a section of my 3d set that develops only for 1/4.
I usually use the command present to create a silky view along a floor, which leaves me half the axieme, or along two floors, which leaves only 1/4.
is somehow possible to select two perpendicular planes and let only 1/4 of the axieme be removed and is not 3/4 as it happens with the general command?
It's just a matter of aesthetics to make pictures to put in a relationship.
I've already found a road. I'm gonna make a new configuration and with an extruded 1/4 cut, I'm gonna take away everything I don't need.
I would like to know if there is a command that allows me to do this without having to go through the extruded cut.
Thank you, matteo
Thank you, matteo
