tilt the pointer lines
  • Thread starter Thread starter Giovannino60
Giovannino60
how to tilt the pointer to 45 degrees in autocad 2007. that is, fold the four lines on the pointer screen.
You mean orienting the bird???? :confused:
command ucs
you can orientate it in x, y and z or move the origin or align it to an object. . .
I have not understood from your answer, I think you have to go on tools, options and intervene them somewhere setting the degrees and the crosses rotate.
I wanted to make a small design in assonometry.
and say it first???? :angry:
variable snapstyl
set to 1
then with f5 commute between the various isoplan... .
but with this system do the isometrics, "ruoting" the pointer to 60°
If you want to make a 45° rider, use the ucs command and tilt on z of 45°
