tilted shutter
  • Thread starter Thread starter march82
march82
in the design I have to carry on cad I have a tilted wall on which I have to insert a window. But every time I go to put it in the program, it puts it perpendicular to the ground. I found a way to tilt it, but it's not perfect. . .
Is there any specific command?
Hello and thank you
If you have autocad full you could try with the "alline" command otherwise you have to move the window to the point of rotation on the wall and then the wheel command with the "referral" option.
if instead the window you still have to draw it then rotate the axles with "object bird" using as object the wall, the axes will align to the wall and you will be able to draw your sloping window to bring back the "normal" axes press "global bird"
but this procedure is good for architecture too?
In theory, since it is in practice an implementation of autocad for architecture, however, just try.. It takes two minutes of clock
