teo's
hi guys, so the problem I have to deal with this time is as follows:
I have to create the 3d of a portion of the soil that you see in the image from the triangular form which, however, must be tilted on that curvilinear side at altitude -3.00 compared to the opposite side lying at altitude + 0.00. I tried to create this 3d with ground modeling but then I get too irregular lines, I tried to treat it as a ramp but it gives me an irreversible problem. So I went to modeling with local mass extruding the mass, but I can't find the tilt command (as for the roof e.g.), always if there is... Does anyone know if I can do what I tried to explain or know maybe an alternative method?? Thank you so much in advance!
