tip for tilted plane
  • Thread starter Thread starter g_i_a_
g_i_a_
Hello, guys.
I put the file for which I need a little help.
I should make an iclined plan instead of the current variable radius fitting.
Is it possible for you?
I tried to do it in a " glance" way, but at the moment, I couldn't complete it.
I wonder what you're doing anyway?
both with the variable radius, and with the variable bevel, I want to see how you will achieve it.
All the rest you do on a normal frieze but that part I really think not.
Why don't you make a normal connection?
In fact, although with a good use of time, the variable radius fitting can do so with a toric cutter, the bevel should still "recommend". . .
I don't feel like I understand what you need, try to see if between the two files I posted there's something you might want
