Mike1967 Guest Mar 16, 2010 #2 libero85 said: Hello everyone, I have a set that I have to be part of, can I? Click to expand... Yes, go to file/save with name and select the .sldprt extension specifying if you want surfaces or volumes.:finger:
re_solidworks Guest Mar 16, 2010 #3 libero85 said: Hello everyone, I have a set that I have to be part of, can I? Click to expand... Mike1967 said: Yes, go to file/save with name and select the .sldprt extension specifying if you want surfaces or volumes.:finger: Click to expand... careful that then you lose every connection. the part becomes end to itself.
Mike1967 Guest Mar 16, 2010 #4 re_solidworks said: careful that then you lose every connection. the part becomes end to itself. Click to expand... Exactly, you do it only in certain cases.
