together and linked files
  • Thread starter Thread starter lillo5
lillo5
Hello, everyone. by little use catia and arrival from other 3d (solidworks, rhino and creo). I am working on rather large assemblies with numerous parts and their drawings.
I did not understand if there is a system that allows me, starting from the aid, to save a kind of package with inside everything (parts and drawings connected) in another folder. I typically have to make special pieces starting from a standard set.
use the rescue management command or send to.
find them under the file menu.
What?
you must have opened the desired design as well.
for example pip design of the particular or pip assembly.
You will see that you can bet on a new folder and define new names for each catpart, cazproduct and catdrawing.
all you save in the new folder will be an independent copy of the original.
all that does not cover in the new folder will remain intact...
Okay, clear. My problem is that they are not where all the drawings are; I have parts taken from different folders and some maybe the design is not even there.
in substance 50 parts in the axieme, I must have opened 50 designs
I would do that.
open a design and save it as new through rescue management.
so also find the links of the various catparts and catproducts that in turn you can save with new names.
