together top-down
  • Thread starter Thread starter Luca79
Luca79
Could someone kindly explain to me in two words how the "top-down" mode, i.e. the one in which some components are created directly in the environment together, and change to the range of a piece instead imported and independent?
just a small example is enough, I tried to make a pin in a perforated plate, but at the varying diameter pin the hole of the plate does not change... :confused:
Thank you!
Thank you!
I may have misunderstood, but if you have created the pin in a set using as the diameter of the pin itself, the projection of the geometry of the hole, you change the diameter of the pin to the variation of the ø of the hole, not vice versa, also because going to change the pin you should see the sketch that creates the diameter of green color, ie' geometry projected or derived from other geometry and therefore not changeable. . . .
Thank you very much, I tried projecting the geometry of the piece and things work.
