together wiring , wire route management
maca75
hello to all, as from the title of the discussion I have some problems with the cablings of inventor, 2017. I have to build a wiring set, something more illustrative than practical, but I can't add points to the wires created to change the path.
I add that I usually work with project files related to the vault pro, but in the specific case all parts and assemblies are located in unmanaged folders directly from the vault.
Unfortunately, with inventor I'm self-taught and I can't get out of it, my guess is that probably being the files together outside of the vault workbook this goes to interfere with the possibility of changing wires.
I ask therefore num to those who are more experienced than me, if someone also has material on how to use wiring I would be grateful.
thanks to all for every possible help
