fabiosam
Good morning to all
I was trying to figure out if it is possible to do this thing I indicated in the title. to explain myself better I made this example that represents a transmission system in a vehicle purposely very stylized.
It consists of 4 wheels, 2 differentials, and 3 axes of which one central and 2 semi-axes. the difference between the central axis and the two semi-axis is that the central one is + long. to build the axes I defined a part for the central axis and one for the two semi-axis. while it would be more useful to define a generic axis part and change only the length when the axis was central or as a semi-axis.
Can you handle such a situation? I have seen that, for example, color can change but if I try to change the length is changed globally.
thanks x ideas/ suggestions
