together with wrong configurations
gtsolid
Hello everyone
I designed a simple 6-axis robot, where I saved configurations: for example when everything is open or closed.
had, now I added a trivial object in the tip and in the configurations that before went, now I find axes rotated 180°, etc...
are there any considerations of bon ton that I must follow?
eh the arm of the robot sticks in the floor instead of being orthogonal upwards for example
I would call them overturning or tipping of the couplings
use axes and plans for couplings reduces the possibility that the couplings go mad.
the term I added a banal object in tip It has no meaning and cannot be deduced anything about the problem.
for problems like this you should have the file and study the couplings (before and after inserting the pointers) and how the axieme was managed and also in that case you may not have an answer.
the upturn of the couplings has been improved with 2016
I updated to 2017 and I must say that the problems did not arise: management is obviously better
good evening to all, I was looking for something similar in list to the forum not to break uselessly, but the temptation is too strong. I have seen this post that speaks of "changes" and I take advantage of it for a question: I have inserted a 2016 sw assembly in total, and for me inexplicably, the movement of a lever that in the assembly is correct, in total it turns out to the contrary. in the sense that captured with the mouse the particular, I must move it up to make it go down...someone knows about it?
if it is inexplicable for you figure for us that we have nothing but a description in which I have to move it up to make it go downto a supplier you would say: I need a piece of iron to make a rectangle that goes wide below then tightens and has a couple of holes on it. ?
I certainly hope not
problem that solved itself, in the morning after rebooting the program. Obviously the graphics went in tilt for some reason. Anyway no, the supplier would also give a couple of pencil indications on a piece of cheese paper, so that I could better understand. Maybe the driver of the fridge first, so that strange things don't happen. I apologize for the trouble. Thanks anyway.
well that it solved itself.
no disturbance, but for correctness to those who read, who takes time to their work or devotes it to the private one, the requests must be exhaustive, well placed, with a comprehensible language using where necessary technical terms and not from the street, correcting them from images and/or explanatory files the question.
