tolerance cumulated dimension
  • Thread starter Thread starter voodoo78
voodoo78
is it possible to tolerate a quota belonging to a series of quotas taken with the command "cumulated dimension"?
If I try, tolerance is applied to the whole series. I would like instead to apply to only one of them.
But... If it's the cumulative odds (which I don't use) , I did some tests and I put the tolerance where I want..................
I can't!
If I insert the quotas with "cumulated dimension" if then I want to assign a tolerance to one of them, the same tolerance is returned to me on all the others.
