Jovanz
Good evening to all,
It's all tonight that I'm trying to figure out if you can see the tolerated size instead of the normal ones on a 3d sw model. I make an example to make me understand better: I drew on a plate a hole of 4 mm diameter, but the carpenter asked me if gently the holes I make them with a tolerance in more than 0.1 mm. Does this mean that in model 3d I have to change all holes to 4,1 mm or is there a way for sw to recognize the tolerated size of the hole of 4mm?
