toolbox measuring unit
  • Thread starter Thread starter Solid User
Solid User
Good evening, everyone. I have set up as custom measuring units for assemblies kg.
default toolboxes have as a measuring unit the g.
there is a way to make default for all toolboxes kg as a unit of measurement?
Thank you in advance for the answers.
https://forum.solidworks.com/thread/44354the explanation is as follows:
you have to edit all the basic files that generate the toolboxes
somewhere you have a toolbox/browser folder (the address of the folder you find in the options in the toolbx card); you can also get there directly from the bread task and by selecting a card or part (I don't remember) with the right button and selecting open folder
in this folder there are all part files that generate toolbox configurations
you have to change the property of the read-only file to not and then open them one by one and change the set of the units
I abolished the toolboxes and made my parametric bolt bookcases. for kisssoft gears and for the rest cadenas or traceparts. the solidworks library is scarce, poor because it cannot be configured properly especially for gears, and if you change pcs and you are not taken behind the toolbox parts you will find everything packed.
see if it's the case of using them.
er the very rare time I use, I change the units in the model that amount.
