toolbox wood and toolbox customization
  • Thread starter Thread starter bibi9000
bibi9000
Hello, everyone.
Does anyone know if there is a toolbox with wood screws and other needles?
I want to customize the creation of holes
if I create a new customization I can not rename the creation folder created holes that recalls the screw
type: flat iso 10642 (the latter cannot vary)
Can someone tell me how I have to do to reassign a non metric but self-tapping screw and change the data?
depends on the version.
return to click on 1 and then on the created folder, you will appear the only holes tabs
Probably no longer in this version. . .
in the creation wizard holes ---1---
Can I change the name of the flared hole I customized and reassigned to another hardware?
then when I create a hole on solid work...the vasation settings are correct but king I do restore default return numbers that you do not know from where they come from.
