hello to all, do you think I made some mistakes in the realization of the attached toothed wheel? I think so, since it's not good for z>=40. The point is I can't figure out where I'm wrong. What advice? ?
with z = 40 manages to create the toothed ruopt.
with >40, no.
at the time I also made a file like that and trying with z>=40, it manages to create the toothed wheel.
If you want I can send you the part file or I'll allow you to search on youtube.
there is a good tutorial in which it explains how to create the toothed wheel, while remaining aware of the curved evolving forums.
in fact i followed the various tutorials on youtube, only that i had problems in generating shape design, in the sense that often gives me "connectivity error" and so i had to do the spola between generative shape design and partdesign. now, apart from the various models found, even here, i would like more to understand where i'm wrong. . .
I do not understand what kind of wheel you are trying to perform, from the part you cannot understand what form you used. I don't see any difficulty running a toothed wheel just follow the formulas and know how to create the tooth evolver and there are no problems.
However as it is very simple perhaps I did not understand your problem well.
Greetings
I downloaded the attached file....
I can't enter a new law... .
Can anyone explain to me how to do this? ? ?
I have seen somewhere that there is also the editor of the laws but I couldn't find him
