GIBO
Good morning to all,
I use revit2009 from neophyte and I wanted to ask you this problem that I found with a topographic surface, its platform for building and underground garage. the question is simple, the attached image summarizes better. the building has a basement floor with platform that eliminates the ground properly. I have inserted an additional platform for the garage, now I have erased it to make better understand, that removes the ground correctly at point 2, but also at the end of the insole at point 1 where instead it must remain. In fact if I look at the 3d I see the cover of the garage and not the appropriately shaped topographic sup. What to do?
