funtanina
Hello everyone,
I kindly ask if any of you can provide you with the exact sequence of operations to perform holes on a catproduct using catia v5r21.
I briefly explain my problem: on a set consisting of a folded sheet box are riveted on the four inner sides of the fixing angles for the cover. to avoid tolerances too much pushed and difficult to realize on the particular of folded sheet, the angles are first riveted, and after drilling for the cover. In this way it is possible to insert more precise tolerances and the puncture of the box shows the same quotas and tolerances of its cover.
Thanks for the answers.
