topsolid limit a bevel along a topsolid side
  • Thread starter Thread starter allumi
allumi
when in a model I make a bevel on one side, it is executed
for the whole length.
which is the command to limit or otherwise do so within certain quotas.
If someone can answer me, thank you in advance.
What exactly does that mean? ...you mean a brusque cut ie from radius 0 to bevel at the same point?
if that's what you mean topsolid doesn't have the command....haimè...(you use a boolean subtraction or a cut for profiles limiting its depth)
Hi, I mean, on a 200mm long side, I'd like to make a bevel
1x45° starting from 15mm from the front side and ending at 15mm from the end of the side, no matter the radius, it will be that of the bevel cutter I will use.
However I think you have already answered me and it seems not possible, thank you
the same for the interest.
I believe that you care little about it, for the purposes of processing you will design a profile starting from 15 and ending at 185 and you will perform a cycle of bevel on profile....and I think you already know the rest:)
In fact, if you only need to run the bevel cycle, simply recover the profile and do the bevel cycle directly in the milling-contorning-musing menu.
if you also need the 3d design of the bevel you must draw the profile with the inclination you need and make the cut for profiles once selected the solid selection the profile enters the avnzate options (button with the double cutters >) and give it the lughness of the bevel. this operation takes a few seconds.
hi, it's true that i can track a profile then tilt and cut for profiles, and it actually works if the side is linear, but in a case where the side
be curved, how do i create the inclination that follows the profile, clearly
i am always talking about a limited profile that does not run throughout the length of the side.
i tried to install topsolid 6.10 on windows7 and it seems that it is compatible, i say, because i tried to work a pocket, in cam, in which i selected the descent "tilt" or "elica" and i can't make it work, this not only in the process "iso", but i don't even see it in simulation (scende directly in z). is it necessary to change some settling?
hi.
hi, excuse for what concerns the pocket I had wrong, it is in fact to select also "external material" as well as "elica" or "tilt" in fact in this way it works and well, still remains the problem of limiting a bevel on a curved side.
hi in this case you have to draw the curve that defines the cut you want on the side that interests you, on the other side you draw the other curve, even a straight profile and then you make a line. made the line you have to make the cut for shapes.
I hope it's clear, if you want, I can send you a movie.
