MassiVonWeizen
another solution is to change the type of deduction of the material by inserting one that is considered more suitable.
to follow these indications:
-open the file of the solidworks materials library with notepad or similar materials (make a security copy)
- identify the voice of the material concerned knowing that the beginning of the list will be <material *per="" -aprire="" -opzioni="" -riavviare="" -salvare="" <xhatch="" alla="" confermare="" dei="" del="" desiderato*="" fino="" i="" il="" inserire="" le="" modifiche="" name="-a" nome="" nomi="" per="" punto="" questo="" solid="" stringa="" tratteggi:="" tratteggio="" visualizzare="">system options > drawing/refilling
- Select the desired drop-down menu and note the name</material>
