training file dxf
  • Thread starter Thread starter carpenteria3
carpenteria3
Good-bye boys. I have to make this template for cycle paths and as a rule the size must be 2 meters in height and 1.5 meters in width, so I would need to stretch the image only towards the other.autocad, catia, tell me if you can do this procedure, thank you.
open the properties and find the scale factor of x, y and z.
change what you need
then I list everything(I'm sorry if I'm disturbing you):
I open the file, create lock, select the design, give it the name to the block and do ok. I open a new window, I paste as lock, property and z put for example value 5, but then nothing happens.
in this way you created a block with another block inside
I put for example the value 5
in autocad z corresponds to the depth that in environment 2d does not serve anything, indeed it only creates problems; in autocad 2d is used x and y.
I recommend doing some tutorials if you don't want to get lost in water glasses
Sorry, you're right, before I wrote it, I made it against ahah .thank you so much for availability, you saved me.
