trajectory on cam
  • Thread starter Thread starter pagatti
pagatti
I am not able to simulate this movement:
the grey sheet is "tired" to the right from the roller moving on a line (in the dis. "Round on the Blue Plan") and so far all right.
the sheet strips on the green profiles (the cam) and here comes the problem:
the transient bond works between the mobile cylinder and the cam while the sheet is not cylindrical.
the tangent bond does not work because on the cam I hang it or on the cylindrical part or on the straight part. . .
I should create a unique surface.
Contact solver does not simulate gravity, and therefore sheet metal at some point "stacca" from the cam. Moreover on inv 11 that I work badly (it seems that the other constraints have a greater priority and cancel the contact) and therefore if I create the cam on the upper part it does not serve anything.. .
Can anyone help me?
n.b. in the images I created the movement "handed" to make you understand
