transform blocking points into single blocks
  • Thread starter Thread starter Fertiland
Fertiland
Hello everyone, it is the first time I use this forum so forgive me in case you make some error of use.
briefly my problem: I have a set of points created by a shape (about 1300)
I would like to turn them into individual blocks.
I can only select them all and turn them into a single block but I can't "divide" them into single blocks.
road map3d
Can someone help me? Thank you.
Maybe if you explain what you need I'm passing through... what are you trying to do?
Yeah, sorry you're right.
So, I would like to point out that it is not fundamental to my work, it is a passage that would still allow me to improve my future activities.
these points correspond to poles of public lighting, each of these points has a set of attributes (lamp, pole height etc.). These 1300 points are obviously not all different, they are a set of 20-25 different models. I ask if I can transform them into single blocks so that these models can reuse them in other contexts and not have to create them again. I know that I could still create my model blocks by turning one to one at least 20-25 different types and I would still have created the library that I have in mind. However in this passage I wondered if there is a possibility to select tot points together and "direct" to map3d to create a different block for each of these points.
I hope I was exhaustive, thank you.
