transform dwg files to tiff or other tips
  • Thread starter Thread starter lunastorta
lunastorta
Hello, everyone.
archaeological study and I am about to graduate with a thesis in archaeology of landscapes, so I used autocad 2014 to draw the archaeological paper in scale 1:25000. having to print more cards for the various phases of population, then print more plotters (which I have never printed, so I don't know the size or costs) I wanted to develop the autocad card in good tiff images, or I had thought to scale everything as a reference in an a4, always develop it as a tiff image and then insert it as a simple table.
Is there a soul of mine and patient that, having understood what I want and must do, can you help me? I would be infinitely grateful.
found on the network pdfill image writer.
install it, then set it to print the resolution you prefer, and in the format you prefer (tiff,jpg etc).
After you set it, in autocad, print on the pdfill printer and you will find an image of excellent quality.
I'll try even though, I think, the only alternative to a good resolution is the printing of the plotter. in this regard, and I apologize for the possible off topic, it is necessary that I carry the computer in copisteria or there is a way to make virtual prints and then to take them in copisteria on a simple pen drive?
pdf printing is bad, it spoils the quality of the project. that I also have the problem of understanding the measures of this card:confused:
It should be the opposite. You obviously misset the settings of your pdf printer.
use dwg to pdf, set it to an output of 600dpi, then you will tell me if it gets hurt or not.
In my opinion there are some initial errors of course the image file 1:25000 to understand if it is in scale should have a square (just to stay in archaeological term), each side of the square measures 1000 meters.
you should check this innent to understand the scale of the drawing.
if the file 1:25000 probably tif format has a correlation file, i.e. a guy.tif file and a file+tizio.tfw if this file you entered it or as an ole image or as reference in autocad 2014 then you are off road, or the stairs according to the instructions above, or with autocad map version which you want, or autocad+apptivo rasterdesign, the file will fit in the right coordinates and
to print scale the desired window personally use the parameters 0.004 above and 1 below (just to be simple) the format seen the scale could also stand in an a4 or in an a3, typically these printed igm sheets are 50x60, print it as a resolution defined by planner and you will see the desired result.
