passi
Good evening, everyone!
I have a problem with autocad3d. I'm modeling a 3d structure and then I can import it into a calculation program, starting with 2d drawings. the structure is composed of flat figures and cylindrical surfaces, joined together.
Is there any way to turn "regions" into surfaces?
In the sense, a full cylinder, if exploded, is divided into various "superfici" described by a base grid. the regions, however, no. this creates problems of congruence then during the import of the model: I would need, in practice, that even the 2d regions were surfaces to make the grids of the cylindrical and flat surfaces coincide, eliminating any problems of congruence.
I don't know if I was clear, but I hope someone can solve or at least help me solve the problem.
Thank you so much!
Thank you so much!
