transformation in dwg dei pdf created con autocad
mbomb
hello to all
are in possession of some tables in pdf format created with autocad. dwg files have been lost and need to make some changes/integrations to the tables. if by autocad (2013) I use the input command, subjected pdf, autocad recognizes in pdf the various objects, but of course I can not make changes.
I was wondering if there is a way to act without having to remake (or recalculate) everything
thanks in advance
There are several free and paid software services that convert but do not expect it to be perfect, especially with free ones! fat that cola if it recognizes the texts as such...the odds will probably be peeled in texts and lines, the debris exploded etc...so I don't say you do first to give it back but certainly not wait for you great things
I was aware of softaware and online services. but just as he said sad the quality is very low. Since I have an illustrator I would opt for this road. Has anyone done this before and can you tell me in a mail order the steps to follow with the adobe programme?
No. there are soft free reading-saving in native dwg format. one of the 2 (I do not remember if nanocad or draftsight) allows the commercial use of its software (and therefore also the saving in dwg) that if opened in acad, will simply bring back the adrt that the dwg was not created with an official version and autodesk product
quotas will probably be peeled in texts and lines, the explosions etc...
and more all in one floor, and of course jumps the scale of the design, the software is obviously illustrator already mentioned by plannerroad
would you tell me that microstation is able to select the individual entities of pdf and even copy them and paste them?! do you link me to a movie where this feature is visible?
I frankly thought it was autocad. However, yes, the copy/paste works from any software including pdf (but also visio , for example; it depends on how pdf is done, for example if it is done with pdf995 I think it is not seen that it is raster.
