gabrielev
Hello everyone,
I need to turn a solid 3d into simple surfaces (the external ones of the solid).
For example, I have a 3d cylindrical structure but I only need its external surfaces.
I need this because I should use the composite module where it is necessary to start from the surfaces to then roll a solid.
I do not know if there is a method for the composite module where you can start directly from solids.
