transmission shaft size
  • Thread starter Thread starter superp
How does this design test work?
studying, I think.
and then:
1) put the photo straight instead of 90° turn
2) propose your solution and then discuss it. learning stems from the critical process of review, and not from being suggested the solutions. unless one studies only to pass the exams and not to learn, benign.
First thing, good evening superp.
second what did you read the forum?
for third, did you introduce yourself?
Fourthly, are you the one who needs to graduate or us? We can help you reason, control methods and procedures. If you don't know where to start, I wonder if you did the proper courses, since you don't know who you are and what you study.
try to restart as you must, and you will see that you will find the solution to the problem.
the guide online solution to your exercise is the following:
- analysis of powers and force agents
- balance sheet and action/reactions on the tree due to the cinematic interaction of the components
- sizing first approximation shaft as well as static verification of the above through rules and rules of good classical design
- draw according to rules of good criterion the system of locking / housing bearings on shaft and hub
- according to static analysis check the most stressed bearing evaluated under dynamic action conditions by looking at binding reactions. use unified method for calculating duration.
for the rest we wait for you.
... I forgot: It is appreciated that you turn the image of the text of the exercise, in order to avoid getting us to take the monitor and turn it 90° on the table, maybe to you it is easy...you are young...we have a certain age:biggrin:
please do the calculations I have the task tomorrow! I know I had to study but I had other checks:confused:
You put them in the concentrated head, manual, book, and you're thinking about it. It's gonna mean you're going to bed at 2:00 in the morning, like I always did, and as you see, I'm still alive. sacrifice helps to grow. . .
I'm desperate... I don't know anything!!! In the end, I think you happened at least once where you slightly copied the verification.. .
If you're at university, you'll take the exam if you're in high school. You will take the vote that will be on average. when I was aware of not knowing I always assumed my responsibilities. first learn and first become responsible adult.
But let me understand... Is this the copy of tomorrow's verification?
I don't think it's at the university if the job you post is 4th of a itis of castelfranco v.to (I know it well that institute).
how did mechanicalmg respond, put yourself on the book and study, even because if we solve the task at the end what you learn? nothing for sure, and if the prof then asks you about this thing you make a silent scene and you "seat" anyway saying you copied
no... but the verification will be based on this
Help me cabbage...if I take another 2 I will have the debt for sure!!!! Please.. I have no manual, no notes and on the book there is nothing written!!! and especially the situation with this professor is a disaster! ! !
I'll think about it. This is the only time I am in this situation!!!!! I don't know anything! !
you have been boys too.....please help me!!! !
You move an action against the teacher by bringing the matter to the Presidency if you feel it necessary. otherwise... few stories and studies. If it's not the first 2 you take with him and every time you don't study and you don't know which side to start. ..may also be a bad teacher who can't teach but you don't study, you don't care, you don't deepen and you don't take lessons.
So... you're gonna fry and study... You've already lost 1 hour in chatter...the two come quickly.. .
Thank you very kind. . .
:biggrin:
I don't understand why one has to be reduced to studying at the last moment. . .
is it not better to study calmly and quickly?
Thank you very kind. Engineer of my boots! ! ! !
you stupid cucchioni think only to yourself and your books and do not help anyone...."basta frignare and put yourself to study" @@@@@@@@@@ you are you who fry if you take 99 instead of hundred!!!!!!!!!!!!!!! Motherfucker!!! make yourself a family!!!!!! @@@@@
Moderate the terms you're not in your house and you can't yell at the whims and insult who and how you want people.
Kid, what we told you from the beginning is that if you think about the exercise (and we are here listening to your reasoning) we can solve this exercise. But if you say "I don't know anything", then what can we do? I did my tricks, my barbine figures when it happened to me for one reason or another that I couldn't or be able to study. and I always had to count on my legs, and if I took a low vote, I had to go to study night and day to take the 8 and recover and prove it was a sporadic thing.
You better open the book, and maybe you'll teach you a little good education before you deal with others.
Does it look like a mature, educated behavior, as a person not spoiled yours? the spoiled do the whims in front of a no. See what to do.
How old are you, kid? learn education and read the forum rules. You came here and pretend that people do your homework for you because you didn't study and you don't want to study. Perhaps and I point out perhaps if you asked the question in different tone you would have found quietly who explained the correct approach to that type of exercise, in this way you just pulled the wedge on your feet.. and in any case certain offensive terms and words keep them for you
