transparency work plans
  • Thread starter Thread starter smoking
smoking
a stupid question: someone can tell me the command to set the transparency / opacity of the work plans. I must have changed something in visualization styles and now the plans appear to me in "full" color obscuring part of the model.
no one has any idea:frown:? ? ?
for completeness: the plans are actually "obscure" only in one direction....
I also have the same problem:
I would like to ask you if there is the possibility to make the work plans in inventor completely transparent (version 2011) since, at the moment, they present transparency only in one direction and opacity in the opposite one.
Thank you!
the plans are transpareted on one side only to indicate what their positive direction is (useful during constraints or if you use them as a sketch plan and insert for example a text). to reverse (do not change) transparency you have to select the plan and button dx; then from the drop-down menu "perpendicular winters"
ok! if it doesn't remember badly in the 2010 version the plans were completely transparent
ok the link posted by shizuru88 and maybe there is the solution but, frankly, I did not understand much.. .
