a question... but the glass if it is moving, in view of section, should not show what is behind it?
how to view things behind the glazed facade panel?
after setting the work plan
you can still draw pattern lines idea!! at the max you can set the glass locks with a visibility parameter and when you need to turn off the glass
here I do it on the antons
