travi revit lt
  • Thread starter Thread starter bonf2
bonf2
Hey, guys, here's my problem today!
I made the decoration of a wooden roof with revit lt; beams and beams.
I have to change the entire project, move it to a topographic surface I got from a relief.
I do not want to move the topographic surface but, acting on the ground floor level, for example, move the entire building to the height I want.
I quoted r blocked various levels, everything works except for beams and beams.
with horizontal beams I solved, quoting their reference plan on the ground floor, blocking the quota and everything works, the beams, which are associated with a tilted reference plane do not move or move incorrectly.
ideas?
Thank you!
but rising above the model the beams stood up but slipped towards the gronda... you know that it is because I drew the beams on a sloped plane.
Would someone know how to indicate the most correct way to draw the ornamentation of a roof with the lt version of revit?
