tele5palla
Hello everyone,
I'm trying in a static analysis of a tree on bronzine, using the static structural module of ansys workbench.
since I am particularly interested in the distribution of pressure on bronzines I am using non-linear formulations of contacts between these and the tree.
the problem is that on one of the bronzine the distribution of pressure is uneven.. you can see an image in the annex.
on the other, however, everything as I expected. What could be the problem? is the famous chattering?
I'll tell you how I set the contacts.
are both frictional, coeff 0.2
asymmetrical
as formulation I used augmented lagrange,
I gave the update stiffness each iteration command
from the initial contact tool there was a gap in one of the two bronzines (the one that works well) that I closed with "adjust to touch"
I strongly hope to receive your help.
asymmetrical
