tree-solid selection
  • Thread starter Thread starter andre91
andre91
Hello, guys, I have a problem on the new post that they entrusted me:
when I pass the mouse on the tree or on a solid, I am not highlighted edges/surfaces and not even the corresponding file part in the tree unless you click (2 times).
in the old station he did it automatically to the mouse passage and I am going crazy to find a solution.
thanks in advance to all
and
practically when I have to select a point or a edge it is no longer enough to place on it and visually verify that I have selected the point or line before selecting one of the two, but you have to click (and despite the click, it is not highlighted what has been selected), all this happens in all environments, whether it is to do the sketch or to select what item of the tree or some feature.
Does anyone have any ideas?
Andrea
hi stef, nothing to do, even so the problem does not solve.
correct me if I'm wrong, but I think it's more general than the display settings, because if I run the mouse dart on the tree, I don't select the various voices/part/product/features as I pass on it, but only if they are clicked 2 times (plus with a good second of wait between 1 click and the other if not I end up in part design environment).
and
try to delete (after copy of the folder) catsetting and see if you have the same problem with the clean catsetting
already but if you reuse the same copy of the settings does not solve.
Could you post pictures? I don't understand the problem. Intuition I think you have a problem of setting or perfotmance with the video card....
What do you mean the same copy of settings??? :confused::confused
clean the catsetting means clear all the content and restart the caia with the blank folder (pulita) do not copy the folder and leave the casetting as it was ............... But maybe I didn't understand what you meant.
this is the classic test to see if you have corrupted some files since what you want to do andre91 would seem like a normal thing that every cat v5 does without touching sects................. .
I meant the same thing, maybe for the user it was not clear how to proceed. Hopefully
Bye.
menu "instruments"--->options....both open a window.
under general--- > view--- > navigation
you must leave "preselection application to geometry" enabled (first entry in the curtain).
we waved
I've been out of office yesterday, I tried the various solutions this morning:
start caia without casetting folder did not solve the problem, and as for leaving the tick on the preselection option, it is active (and I reactivated it after deleting catsetting), but the solution does not come.
to better make the idea (maybe it was just my pc that did it but it was extremely comfortable), in any environment, passing from one surface (of any type) to another, selecting one or the other automatically; riding in the tree in product environment (so scrolling the various parts), simply scrolling over I found myself highlighted both the name in the tree and the corresponding solid (without needing to click on it!);
but the most annoying thing occurs in the sketch phase, when I go to bind it, I do not select the segments, faces or points passing on (and then having a visual feedback on what I am doing), but I have to click and hope to have taken the right geometry (and between line and point is a nice problem to take the point instead of line)!
it would take a video and if it doesn't have to be clear to someone the explanation, I will equip myself to do it:-)
thanks to all
Andrea
the version is 5.21, if you can kindly give me some tips of where to find the other info, I'll send them to you by flight :biggrin:
caria v5r21 is full of beaks.... He's giving me a world of trouble. .
or go back to 20 or wait 22....
I can't find anything about service pack.
if you didn't find anything (it was what I thought) you put at least
the spk1, I use the r20 and do not know where they arrived with the servicepack, so that there is the spk1.
cmq should never be used the catia version (without servicepack)
xthat is never (or almost) reliable . :smile:
