tree symbolism clarifications feature
  • Thread starter Thread starter fedcas
fedcas
I have seen that the feature tree uses a lot of symbolism in the "text" of the features, most of the things I have understood (such as the indications for underdefined sketches, for fixed parts, for parts included in the asm file or referenced in external files etc) but there are some that still obscure me:
What do the arrows indicate? and the arrows + question mark?
as I know:
Arrow = geometry connected to referencearrow +? = connected geometry in interrupted reference
I add: the arrow indicates an external reference, while the interrupted one indicates that the reference, at that time, is not resolved.
if for example models a part in the context of a set create external references (fresh). If you close the axieme, keep the part open and do ctrl+q appears the ? because the reference is no longer resolved.
understood ;) and I solved the missing references by clicking dx => lists external references to see what had happened... Thanks :)
Um... and this hat icon what is it?
hello to all;
I also have this problem; I create a part (strap) defined in the context of a set.
When I reopen, I get the question mark out; in the list of references, tells me that all the sketch defined in the axieme is out of context.
What does that mean? How do I solve without each time remake all relationships?
I have already tried several times: I define relationships again but it returns to be out of context.
aid :
Thank you!
hello to all;
aid :
Thank you!
but reopen the asse, or reopen the belt,
because if you reopen the belt they miss the references, and it will tell you out of context.
but if, together with the belt, the axieme where there are references must go all right.
If I reopen the assist and load the belt, I appear the question marks and lose the references;
I don't understand why;
the sketch remains black without misrepresentation (it does not signal the missing relationship in brown, but remain green);
despite trying to resurrect with ctrl+q and ctrl+b, with joint and open belt, I do not recover my relations;
How can I do that?
How can I do that?
I'm sorry I'm late, I'm sorry, but it doesn't happen to me, I'm stuck in 2014, and it works smoothly.
