vingal
Hello attached there is a tree with the two spherical heads, I have to simulate his movement with the kinematics, on the one hand it is I bound it with a spherical joint and then rotation inside a support, and this is good and the movement is good, on the other side it has to remain within another equal support only that here it must stop without revolving also the same support must be firm, in a simple contact me. I tried with a spherical joint but it does not allow me to do so. I thank you in advance.
