trees
  • Thread starter Thread starter daniele rubis
daniele rubis
Bye. I wondered if two vertical shafts could be combined with one horizontal shaft, all must be rotated
Maybe if the information is more accurate like:
who and how to rotate
what you want to get
materials and forces at stake
tree scheme
... whatever you know or think you know
as it is a technical forum it would be useful and educational to try to use a technical language or at least specific of the field we talk about.
you help, you correct, but to do so you need common ground
then I have blades attached to the center in a tree then from this tree I have to connect 2 vertical trees if it was just one I would put a conical wheel and I would be affixed but with 2 I don't know how to do
So to the eye, I'd put two corners of business... but it is hard to interpret the ideas of others, we are not magicians! :-)
I see 3 horizontal trees... I think we have to bring the good leonardo back to life!
Let's take it on the laugh... It's not my intention to tease anyone, I'd like to help with what I can and can do, but... I have limits!
Daniele, apart from the jokes, instead of posting images that do not represent your problem, put your sketch with some notes of what you want to get.
two trees come together in a pot with the earth...
Why can't you make a pattern with the pen on a sheet and put down an idea?
technicians who make philosophers? No... drawings take us.
I attach pattern with two trees turning.... joined by a vertical shaft through cylindrical helical wheels and then a conical couple.IMG_20200131_201037.webp
Don't be afraid, we're waiting, the only stupid questions are those not asked!
We are here to help us all and not to judge, each from what you know and can, only so you learn!
I'm sorry I didn't see the design, I'm sure you can do it, but to do it and how to do it, you need to know the powers at stake, speeds, dimensions...
If it's a prototype for you, if it's a machine to put in production, the budget you have. . .
is a little more different from "2 vertical trees and a single horizontal" seems to me.
mechanically feasible, but as has been said, we must do well the calculations of forces to optimize the project
the design you posted is mechanically possible. as my colleagues told you, you must first determine the torque and rotation regime you need on users.
then it is necessary to move to the sizing of all gears and their verification. later it is necessary to make the calculation of duration of the bearings and the sizing of all the trees.
definitely need to know service factor, intermittent service, humid environment, dusty, hot, etc.
idea of budget, possibility to use components from trade at least for gears (purchase from stock) or custom size and therefore construction from specialists to single design.
for purchases in stock I would say that misumi is the best.
Section nignagi cylinders
Section nignagi conical
couples conical already mounted
