tri-tangent connection
  • Thread starter Thread starter Utente NX
Utente NX
I would like to create a fitting as from attached image.
I followed the pdf guide, but I don't get out of the connection.
Can you give me the solution?
Thank you. .
cable: eek:
but how many options do you have?
it takes a week to use it well:biggrin:
I do not know catià, but there are 5 commands inherent to the rays and each of them has many options.
nx on modeling is unexceptionable... allows you to do everything.
I attached an example.
I had to put the real piece to make you understand?
Can you do the tri-tangent radius? That was my question.
If only I had placed immediately the request for help inherent a tritangent ray instead of asking "I want a ray like that ":36_6_6: maybe the answer would have arrived .
Also you have failed to indicate which version of nx you are using and for which you ask for help.
the blend command as it suggested matrix with the passing of the releases had an important evolution.
therefore be quiet and try in the future to post the questions by providing all the necessary elements for you to ditch help.
:36_1_3:
:36_1_3:
Of course if it wasn't clear my initial question, then there is a background problem.
the version used is in my signature, if you did not notice.
We're good anyway.
apparently it was not clear at all if placed a pdf contain a three face blend that refers to nx5.
I'm glad you're good.
We're good anyway.
I have noticed, in fact, the examples I have always sent them to nx7, but I have also noticed that the annexed pdf covers version nx5 and I was answering you as ip :finger:.
a scanso di equivoci... (for those who have no nx or for those who have previous versions nx7.5)
before nx7.5 the tritangent only works if the "central" face (that to be replaced) is flat or is a plan.
from nx7.5 life changes ( fortunately)
switch from one release to another with tc and in a company like our not thing for a couple of days.
We agreed we'll go to 8.
I know.
I was joking. . .
to understand:
1) what version of tc you have and what do you plan to migrate to?
2) when do you think you are migrating?
the pdf attached is a gtac_quarterly.
I could also attach a gtac_quarterly of nx1 if it comes to some still current solution.
I know.
I was joking. . .
to understand:
We currently have tc8 as signature.
with nx8 there should also be tc9.
the update will have to be planned after nx8 will be released.
Wow!
I often read it myself... sometimes there are interesting things. :wink:
I have never written any article.:mixed:
We currently have tc8 as signature.with nx8 there should also be tc9.
Sorry :redface: I had not read the signature.
for nx8 I think there will be no problem.. .
(nx8.5 comes out in q1 2012, but will be tagged on specific industry)
I don't remember the release time of tc9.
