mainagioia
Good morning.
I address designers who have worked in guitar companies but not only. for those who did not know there is a metal element, called truss rod that properly adjusted allows, in the guitar handle, to balance the tension of the strings. usually adjusts with a wig to the guitar shovel, in rare cases to the handle with a screw. I have a guitar with adjustment to the handle, but it's not a screw I believe. In the standard case of adjustment to the handle, I should disassemble the entire handle and turn the screw inside, in my case instead I see side holes and I wonder if they serve somehow to turn the element without disassembling the guitar. The guitar is a yamaha rgx520dz and has a series of patented functions ex novo, so I would like to understand whether even this is an innovative element or if it is a simple screw. Have you ever found similar elements in your career? From the engineering point of view, what's his name? in what designs can be used? in the future I would like to be able to work in this type of industry, so I would like to be able to understand something more and from the design point of view I would like to know any new elements. Thank you.
