dutlui
Hi, I tried to search on the forum a suitable lisp but I found nothing.
before applying this great lisp insert-points-and-text-sui-vertici- of-a-poliline would be useful a command to "turn" the polyline horizontally - as you have already understood is for the management of a profile.
other lisp that I did not find is on the management of xrif layers - it happens to load xrifs with many layers - usually almost all imposed them with standard thickness and color, but some (about ten) should have different colors and thicknesses. the convenient thing is that the names of these layers are always the same (some have a similar name, type *1f00*). to not select them by hand every time an automatic command would be the top.
