tutorial layout con mechanical
Emanuele8210
hi guys are a napkin with mecanical, where I find a good tutorial to work in the paper space with the mechanical ...today 20.02.2017 I made the installation , I think I have the version 2016 . thanks also I accept short answers ...today I couldn't even bring the model into the layout area .
for basic use the thing is quite simple: design in the model space, always in the model space create a window with area (amscarea) where you set the scale factor and then select which layout you want to create it. made this in the chosen layout will be created a window corresponding to that of the model and with its scale ratio.
to enter a little more on the amscarea command: all mechanical or power entities such as odds, roughness and similar symbolism designed within the area (of course in the model space) will take on the scale ratio size; by modifying this report and selecting all these entities (you can also select everything contained in the area as the operation only applies to power entities) will be automatically adapted. going then into layout space and selecting the window edge with a double click also this will be adapted.
I add a link where I explained it in a leaner way http://www.cad3d.it/forum1/threads/...te-e-quotature?p=149306&viewfull=1#post149306
